Einleitung
You will need to replace the flash cover if the camera will not take clear pictures, has a cracked or scratched cover. You will need to use the Shutter Switch Replacement guide as a precursor guide.
Was du brauchst
Unscrew the four 5mm screws on the base of the camera. Remove the two pieces of the base.
Unscrew the four 5mm screws on the top of the inside base piece.
Unscrew the two 5mm screws on the bottom of the inside base piece which is near the strap.
With force separate the front white piece from the back of the camera. You will use your hands to pull it apart.
2 weitere Personen haben diese Anleitung absolviert.
