Einleitung
Being able to remove the keyboard will allow you to replace it or clean up the connections if the keyboard is not working properly.
Was du brauchst
Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
