Zum Hauptinhalt wechseln
PowerBook G4 Titanium Mercury RAM Replacement
Was du brauchst
    1. PowerBook G4 Titanium Mercury RAM Replacement, Keyboard: Schritt 1, Bild 1 von 1
      • Remove the battery.
      • Turn the keyboard locking screw so that it is parallel to the space bar.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      Frag FixBot
      Kommentar hinzufügen
    2. PowerBook G4 Titanium Mercury RAM Replacement: Schritt 2, Bild 1 von 1
      • Rest the keyboard face down on the trackpad area.
      • Disconnect the keyboard connector from the logic board.
      Frag FixBot
    3. PowerBook G4 Titanium Mercury RAM Replacement: Schritt 3, Bild 1 von 1
      • Your laptop should look approximately like this.
      Frag FixBot
    1. PowerBook G4 Titanium Mercury RAM Replacement, RAM: Schritt 4, Bild 1 von 1
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the RAM chip out.
      • Repeat this process if a second RAM chip is installed.
      Frag FixBot
Abschluss
13 weitere Personen haben diese Anleitung absolviert.
Angehängte Dokumente
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 40
Insgesamt: 9,959
