Einleitung
If your device will not turn on at all, use this guide to replace your dead or dying battery and make your device functional again.
Was du brauchst
Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a soldering tool and tweezers to remove the black and red wire from the motherboard.
Using the flat end of a spudger, carefully separate the battery from the base of the device.
3 weitere Personen haben diese Anleitung absolviert.
