Zum Hauptinhalt wechseln
ProScan PLT7223G Screen Replacement
Was du brauchst
  1. ProScan PLT7223G Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
    Frag FixBot
    Kommentar hinzufügen
  2. ProScan PLT7223G Screen Replacement: Schritt 2, Bild 1 von 1
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
    Frag FixBot
  3. ProScan PLT7223G Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove three 4 mm screws from the motherboard.
    Frag FixBot
  4. ProScan PLT7223G Screen Replacement: Schritt 4, Bild 1 von 1
    • Insert a spudger under the black tape that connects the silver wire to the interior of the front panel
    • Pull back the black tape with the spudger until it can be lifted up with your fingers.
    • Use your fingers to grab and lift the remainder of the black tape from device panel.
    Frag FixBot
  5. ProScan PLT7223G Screen Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to push back the ZIF connector to release the ribbon wire on the motherboard.
    Frag FixBot
  6. ProScan PLT7223G Screen Replacement: Schritt 6, Bild 1 von 1
    • Insert an opening tool underneath the silver base of the internal device element.
    • Use the opening tool to pry the element out of the case that holds the screen.
    • You will need to release a number of clips in order to remove the screen.
    • Be careful not to damage the motherboard or battery as you go.
    Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 2,095
