Zum Hauptinhalt wechseln
ProntoTec Axius Camera Replacement
Was du brauchst
    1. ProntoTec Axius Camera Replacement, Camera: Schritt 1, Bild 1 von 1
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table.
      Frag FixBot
      Kommentar hinzufügen
    2. ProntoTec Axius Camera Replacement: Schritt 2, Bild 1 von 1
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      Frag FixBot
    3. ProntoTec Axius Camera Replacement: Schritt 3, Bild 1 von 1
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      Frag FixBot
    4. ProntoTec Axius Camera Replacement: Schritt 4, Bild 1 von 1
      • Remove only the yellow tape that touches the battery.
      • Be careful not to cut or damage the wires (red and black) that are under the yellow tape.'
      Frag FixBot
    5. ProntoTec Axius Camera Replacement: Schritt 5, Bild 1 von 2 ProntoTec Axius Camera Replacement: Schritt 5, Bild 2 von 2
      • Use the flat end of the spudger to gently pry the top left corner battery from the back of the screen in order to access the camera.
      Frag FixBot
    6. ProntoTec Axius Camera Replacement: Schritt 6, Bild 1 von 3 ProntoTec Axius Camera Replacement: Schritt 6, Bild 2 von 3 ProntoTec Axius Camera Replacement: Schritt 6, Bild 3 von 3
      • Use the spudger to lift the black clamp as shown in the photo to disconnect the camera from the motherboard.
      Frag FixBot
    7. ProntoTec Axius Camera Replacement: Schritt 7, Bild 1 von 2 ProntoTec Axius Camera Replacement: Schritt 7, Bild 2 von 2
      • Disconet the camera from the motherboard.
      • Pull the camera from the back of the screen.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 5-3, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Mitglieder
21 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 31
Insgesamt: 465
