Einleitung
This guide shows how to remove the blade guard on the Protocol Dronium Two. The only tool you will need is the #0 Phillips screwdriver. The screwdriver is also included in the box of your drone. Perform this repair in a clean and well lit area so that you don't lose the screw.
Was du brauchst
While holding the drone with one hand, gently lift the blade guard straight up and remove it.
2 weitere Personen haben diese Anleitung absolviert.
