Zum Hauptinhalt wechseln
Raspberry Pi 3 SD Card Replacement
Was du brauchst
  1. Raspberry Pi 3 SD Card Replacement, Raspberry Pi 3 SD Card replacement.: Schritt 1, Bild 1 von 1
    • The Raspberry Pi 3 should look like this closed.
    Frag FixBot
    Kommentar hinzufügen
  2. Raspberry Pi 3 SD Card Replacement, Top cover removal: Schritt 2, Bild 1 von 1
    • Open the top lid like I have done on the image.
    • The top is marked that you are gonna remove in the next step.
    Frag FixBot
  3. Raspberry Pi 3 SD Card Replacement, Cover for GPIO Hider and IO Shield removal: Schritt 3, Bild 1 von 1
    • Now remove the cover for the two covers.
    • It should look like the image.
    • I have marked the covers for the next step.
    Frag FixBot
  4. Raspberry Pi 3 SD Card Replacement, IO Shield and GPIO Hider removal: Schritt 4, Bild 1 von 1
    • Remove the two sides.
    Frag FixBot
  5. Raspberry Pi 3 SD Card Replacement, Removal.: Schritt 5, Bild 1 von 2 Raspberry Pi 3 SD Card Replacement, Removal.: Schritt 5, Bild 2 von 2
    • Now we should successfully have removed the case.
    • Notice that the side shown on the first image is the one that we are intrested in.
    • When we have flipped the Pi 3 over we can remove the SD card.
    Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 39
Insgesamt: 2,711
