Einleitung
The SD Card is required to save each photo before taking the next photo. This guide will show the proper steps to reformat the SD Card.
Turn the camera on by sliding the switch from the "Off" position to the "On" position. The switch is located above the touchscreen and to the left.
The screen will say "Sensor cleaning" once the switch is moved to "On".
Scroll down the list using the thumb pad and select, "Format card" by pressing the center of the thumb pad labeled, "SET".
Press the right side of the thumb pad to move over the "Ok" button.
Once "OK" is highlighted, press the middle of thumb pad to initiate the formatting of the card.
