Zum Hauptinhalt wechseln
Rexing V1P Plus Front Camera Replacement
Was du brauchst
    1. Rexing V1P Plus Front Camera Replacement, Front Camera: Schritt 1, Bild 1 von 3 Rexing V1P Plus Front Camera Replacement, Front Camera: Schritt 1, Bild 2 von 3 Rexing V1P Plus Front Camera Replacement, Front Camera: Schritt 1, Bild 3 von 3
      • Begin by orienting the device with the LCD screen facing down.
      • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. Rexing V1P Plus Front Camera Replacement: Schritt 2, Bild 1 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 2, Bild 2 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 2, Bild 3 von 3
      • Remove the back cover of the device and place it to the side.
      • Rotate the device 180 degrees to where the camera is facing you.
      Frag FixBot
    3. Rexing V1P Plus Front Camera Replacement: Schritt 3, Bild 1 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 3, Bild 2 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 3, Bild 3 von 3
      • Remove the two 5 mm screws next to the lens using the Phillips #00 screwdriver.
      Frag FixBot
    4. Rexing V1P Plus Front Camera Replacement: Schritt 4, Bild 1 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 4, Bild 2 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 4, Bild 3 von 3
      • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
      Frag FixBot
    5. Rexing V1P Plus Front Camera Replacement: Schritt 5, Bild 1 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 5, Bild 2 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 5, Bild 3 von 3
      • Remove the two 5mm screws securing the camera support bracket using the Phillips #00 screwdriver.
      Frag FixBot
    6. Rexing V1P Plus Front Camera Replacement: Schritt 6, Bild 1 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 6, Bild 2 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 6, Bild 3 von 3
      • Carefully remove the plastic frame piece from its previously secured position on the motherboard.
      • It will rest loosely around the white camera ribbon.
      • Rotate the device 180 degrees to where the camera is facing away from you.
      Frag FixBot
    7. Rexing V1P Plus Front Camera Replacement: Schritt 7, Bild 1 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 7, Bild 2 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 7, Bild 3 von 3
      • Carefully peel back the adhesive material covering the ribbon cable connection.
      Frag FixBot
    8. Rexing V1P Plus Front Camera Replacement: Schritt 8, Bild 1 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 8, Bild 2 von 3 Rexing V1P Plus Front Camera Replacement: Schritt 8, Bild 3 von 3
      • Using the Flathead 1.5mm screwdriver, or another pry tool, gently flip up the black ZIF connector locking flap to free the ribbon cable.
      • Once the connector is open, slide the ribbon cable out to remove it.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 377
