Zum Hauptinhalt wechseln
Ring Video Doorbell Camera Replacement
Was du brauchst
    1. Ring Video Doorbell  Camera Replacement, Camera: Schritt 1, Bild 1 von 3 Ring Video Doorbell  Camera Replacement, Camera: Schritt 1, Bild 2 von 3 Ring Video Doorbell  Camera Replacement, Camera: Schritt 1, Bild 3 von 3
      • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
      • Pry open the aluminum plate using the Plastic Opening Tool(s).
      • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. Ring Video Doorbell  Camera Replacement: Schritt 2, Bild 1 von 3 Ring Video Doorbell  Camera Replacement: Schritt 2, Bild 2 von 3 Ring Video Doorbell  Camera Replacement: Schritt 2, Bild 3 von 3
      • Pry open the back case as shown using the Plastic Opening Tool.
      • Disconnect the battery from motherboard by carefully pulling up on the connector.
      Frag FixBot
    3. Ring Video Doorbell  Camera Replacement: Schritt 3, Bild 1 von 3 Ring Video Doorbell  Camera Replacement: Schritt 3, Bild 2 von 3 Ring Video Doorbell  Camera Replacement: Schritt 3, Bild 3 von 3
      • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
      • Carefully detach the motherboard, from the housing unit using your hands.
      Frag FixBot
    4. Ring Video Doorbell  Camera Replacement: Schritt 4, Bild 1 von 2 Ring Video Doorbell  Camera Replacement: Schritt 4, Bild 2 von 2
      • Using the Plating Tool Opener, arefully disconnect the ribbon cable that attaches the camera to the housing.
      • Replace camera, and follow the steps in reverse order to reassemble
      Frag FixBot
    5. Ring Video Doorbell  Camera Replacement: Schritt 5, Bild 1 von 2 Ring Video Doorbell  Camera Replacement: Schritt 5, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Unscrew the two 1 mm screws using the PH00 Philips Screwdriver.
      • Detach the black and red wire connected to the motherboard, using the tweezers, to remove the camera.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S11-G5, Cheng Spring 2018 Mitglied von USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Mitglieder
15 Anleitungen geschrieben
11 Kommentare zur Anleitung
What camera should I use to replace a malfunctioning camera in the ring video doorbell? And where do I buy it?
jonathan.byus - Antwort Teilen
Bump. What camera should I use to replace? (Scratched Lens.) Is the lens you can touch, a lens, or is it just a cover? Mine fell at there is chip right in the center that make the image unusable.
Bobby Diggins - Antwort Teilen
I have a scratch dead center of mine too. Have no clue how it got there as I’m super careful when I take it off to charge. Ugh. did you find out where to buy a replacement?
Kim Townsend - Antwort Teilen
What camera should I use to replace? (Scratched Lens.)  I have the right 1st generation with a 740p camera
meanltltoo - Antwort Teilen
Has anyone found a replacement camera online?
christina.stewart - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 29
Letzte 30 Tage: 160
Insgesamt: 20,626
