Zum Hauptinhalt wechseln
Roku 4 Motherboard Replacement
Was du brauchst
  1. Roku 4 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
  2. Roku 4 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
    • Completely remove the rubber sticker to reveal the underlying screws on the device.
    • Place the rubber sticker facing up on the table to preserve its adhesiveness. It will be needed to reassemble the device.
  3. Roku 4 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
    • Store the screws in a safe place, such as on a magnetic project mat, so they do not get lost before reassembly.
  4. Roku 4 Motherboard Replacement: Schritt 4, Bild 1 von 2 Roku 4 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Turn the device over so you can see the "4" on the top cover.
  5. Roku 4 Motherboard Replacement: Schritt 5, Bild 1 von 2 Roku 4 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
    • Prying open the device is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
  6. Roku 4 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
    • The motherboard should still be attached to the underside of the top cover by a red wire, a blue wire, and a black wire.
  7. Roku 4 Motherboard Replacement: Schritt 7, Bild 1 von 3 Roku 4 Motherboard Replacement: Schritt 7, Bild 2 von 3 Roku 4 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
    • Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
  8. Roku 4 Motherboard Replacement: Schritt 8, Bild 1 von 3 Roku 4 Motherboard Replacement: Schritt 8, Bild 2 von 3 Roku 4 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Peel back the black adhesive strip that attaches the blue wire to the motherboard.
    • Repeat this step for the strip that attaches the black and red wires to the motherboard.
  9. Roku 4 Motherboard Replacement: Schritt 9, Bild 1 von 3 Roku 4 Motherboard Replacement: Schritt 9, Bild 2 von 3 Roku 4 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
    • Consult iFixit's Soldering Skills guide to safely use the soldering iron.
    • The motherboard should now be completely disconnected from the top cover of the device.
Abschluss
Follow these steps in the reverse order to reassemble your device.
7 weitere Personen haben diese Anleitung absolviert.
Baylor, Team S5-G4, Williams Spring 2017 Mitglied von Baylor, Team S5-G4, Williams Spring 2017
BU-WILLIAMS-S17S5G4
3 Mitglieder
4 Anleitungen geschrieben
4 Kommentare
Thank you, have you upgraded to a new 2019 Ultra model yet?
Allan Landwer - Antwort
Soldering the fan to the mobo is a suck move. However, they used a good quality bearing-less fan.
smbrannon - Antwort
Can you gve me areson? will it suck out the perfomance?
Kind-hearted, spirited Man -
Because it makes replacing the motherboard more difficult. For a few cents more, they could have placed a small connector inline between the fan and motherboard, making disconnecting the fan and top case really easy.
Bob Reed - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 36
Insgesamt: 5,482
