Zum Hauptinhalt wechseln
Rotary Multi Selector Wheel Removal
Was du brauchst
    1. Rotary Multi Selector Wheel Removal, Back Cover Removal: Schritt 1, Bild 1 von 3 Rotary Multi Selector Wheel Removal, Back Cover Removal: Schritt 1, Bild 2 von 3 Rotary Multi Selector Wheel Removal, Back Cover Removal: Schritt 1, Bild 3 von 3
      • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
      • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
      • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
      Frag FixBot
      Kommentar hinzufügen
    2. Rotary Multi Selector Wheel Removal: Schritt 2, Bild 1 von 1
      • Carefully remove the back casing from the camera.
      • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
      Frag FixBot
    3. Rotary Multi Selector Wheel Removal, Detaching Ribbon: Schritt 3, Bild 1 von 2 Rotary Multi Selector Wheel Removal, Detaching Ribbon: Schritt 3, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
      • Gently pull the ribbon from the logic board with tweezers.
      • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
      Frag FixBot
    1. Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: Schritt 4, Bild 1 von 3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: Schritt 4, Bild 2 von 3 Rotary Multi Selector Wheel Removal, Rotary Multi Selector Wheel: Schritt 4, Bild 3 von 3
      • Lift up the metal cover and its button slowly using the tweezers.
      Frag FixBot
Abschluss
Andrew Lau
1 Reputation
1 Anleitung geschrieben
Cal Poly, Team 8-56, Johann Spring 2013 Mitglied von Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 32
Insgesamt: 1,027
