Zum Hauptinhalt wechseln
SG 552-1 Commando Spring Replacement
Was du brauchst
    1. SG 552-1 Commando Spring Replacement, Gearbox: Schritt 1, Bild 1 von 2 SG 552-1 Commando Spring Replacement, Gearbox: Schritt 1, Bild 2 von 2
      • Using a flathead screwdriver, remove the pin holding the hand guard in place.
      • To remove this, turn the pin clockwise and push it through at the same time.
      • Remove the hand guard.
      Frag FixBot
      Kommentar hinzufügen
    2. SG 552-1 Commando Spring Replacement: Schritt 2, Bild 1 von 2 SG 552-1 Commando Spring Replacement: Schritt 2, Bild 2 von 2
      • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
      • There should be four total.
      Frag FixBot
    3. SG 552-1 Commando Spring Replacement: Schritt 3, Bild 1 von 2 SG 552-1 Commando Spring Replacement: Schritt 3, Bild 2 von 2
      • Turn the gun over so that you are facing the bottom of the gun.
      • Using a Phillips #1 screwdriver, remove the following screws:
      • Remove the 8mm screw that is located directly underneath the cocking lever.
      • Remove the 8mm screw located beside the screw you just removed.
      Frag FixBot
    4. SG 552-1 Commando Spring Replacement: Schritt 4, Bild 1 von 2 SG 552-1 Commando Spring Replacement: Schritt 4, Bild 2 von 2
      • Carefully tug on the tip of the gun and pull the barrel and its cover out.
      Frag FixBot
    5. SG 552-1 Commando Spring Replacement: Schritt 5, Bild 1 von 3 SG 552-1 Commando Spring Replacement: Schritt 5, Bild 2 von 3 SG 552-1 Commando Spring Replacement: Schritt 5, Bild 3 von 3
      • Locate the hand grip.
      • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
      • Slide the cover off.
      Frag FixBot
    6. SG 552-1 Commando Spring Replacement: Schritt 6, Bild 1 von 2 SG 552-1 Commando Spring Replacement: Schritt 6, Bild 2 von 2
      • Pull the motor out of the hand grip.
      • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
      Frag FixBot
    7. SG 552-1 Commando Spring Replacement: Schritt 7, Bild 1 von 2 SG 552-1 Commando Spring Replacement: Schritt 7, Bild 2 von 2
      • Locate the pin holding the folding stock in place.
      • Using an allen wrench or something small, carefully push the pin out.
      Frag FixBot
    8. SG 552-1 Commando Spring Replacement: Schritt 8, Bild 1 von 2 SG 552-1 Commando Spring Replacement: Schritt 8, Bild 2 von 2
      • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
      • Remove the cover that was held on by the screw.
      Frag FixBot
    9. SG 552-1 Commando Spring Replacement: Schritt 9, Bild 1 von 3 SG 552-1 Commando Spring Replacement: Schritt 9, Bild 2 von 3 SG 552-1 Commando Spring Replacement: Schritt 9, Bild 3 von 3
      • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
      • Slide off the piece that was held on by those screws.
      Frag FixBot
    10. SG 552-1 Commando Spring Replacement: Schritt 10, Bild 1 von 2 SG 552-1 Commando Spring Replacement: Schritt 10, Bild 2 von 2
      • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
      • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
      Frag FixBot
    11. SG 552-1 Commando Spring Replacement: Schritt 11, Bild 1 von 2 SG 552-1 Commando Spring Replacement: Schritt 11, Bild 2 von 2
      • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
      • Carefully remove the pieces that were held on by the screws.
      Frag FixBot
    12. SG 552-1 Commando Spring Replacement: Schritt 12, Bild 1 von 3 SG 552-1 Commando Spring Replacement: Schritt 12, Bild 2 von 3 SG 552-1 Commando Spring Replacement: Schritt 12, Bild 3 von 3
      • Pull apart the cover when pulling the gearbox out.
      • Pull the gearbox out.
      • The gears will fall out when taking the gearbox out. Careful not to lose them.
      Frag FixBot
    1. SG 552-1 Commando Spring Replacement, Spring: Schritt 13, Bild 1 von 2 SG 552-1 Commando Spring Replacement, Spring: Schritt 13, Bild 2 von 2
      • Remove these four 15mm screws.
      • Remove this single 8mm screw.
      • Using a Phillips #0 screwdriver, remove the following screws:
      • Remove this single 3mm screw.
      • Remove this single 14mm screw.
      • Detach the pieces unscrewed from the gearbox.
      Frag FixBot
    2. SG 552-1 Commando Spring Replacement: Schritt 14, Bild 1 von 2 SG 552-1 Commando Spring Replacement: Schritt 14, Bild 2 von 2
      • Remove the piece covering the trigger.
      • Remove the safety piece.
      • Using a Phillips #1 screwdriver, remove the 18mm screw beside the trigger.
      Frag FixBot
    3. SG 552-1 Commando Spring Replacement: Schritt 15, Bild 1 von 1
      • Remove the metal piece.
      • Removing this piece will permanently damage the metal piece.
      Frag FixBot
    4. SG 552-1 Commando Spring Replacement: Schritt 16, Bild 1 von 3 SG 552-1 Commando Spring Replacement: Schritt 16, Bild 2 von 3 SG 552-1 Commando Spring Replacement: Schritt 16, Bild 3 von 3
      • Remove the cover and pull out the spring.
      Frag FixBot
Abschluss
Anika Morris
1 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-41, Regan Fall 2012 Mitglied von Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Mitglieder
6 Anleitungen geschrieben
1 Kommentar zur Anleitung
When i read step 15 it seems impossible to up/downgrade spring without damaging the gun permanently??
Marco den Hartog - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 35
Insgesamt: 2,357
