Einleitung
Use this guide to remove or replace your Samsung Galaxy Note II's battery.
If your battery is swollen, take appropriate precautions.
Was du brauchst
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
33 weitere Personen haben diese Anleitung absolviert.
