Zum Hauptinhalt wechseln
Samsung Galaxy Note9 Iris Scanner Replacement
Was du brauchst
  1. Samsung Galaxy Note9 Iris Scanner Replacement, Apply a heated iOpener: Schritt 1, Bild 1 von 1
    • Power off your phone before beginning disassembly.
    • Use a hairdryer, a heatgun, or prepare an iOpener and apply it to the right edge of the back of the phone for about a minute to soften the adhesive underneath.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung Galaxy Note9 Iris Scanner Replacement, Insert an opening pick: Schritt 2, Bild 1 von 3 Samsung Galaxy Note9 Iris Scanner Replacement, Insert an opening pick: Schritt 2, Bild 2 von 3 Samsung Galaxy Note9 Iris Scanner Replacement, Insert an opening pick: Schritt 2, Bild 3 von 3
    • Apply a suction handle to the back cover.
    • Lift with a suction handle to create a gap between the back cover and the frame of the phone.
    • Insert an opening pick into the gap.
    • If the glass is badly cracked, cover it in packing tape to create a surface for the suction cup to adhere to.
    • If the adhesive won't budge, apply more heat, not excessive force. Too much force could break the glass.
    Frag FixBot
  3. Samsung Galaxy Note9 Iris Scanner Replacement, Cut through the adhesive: Schritt 3, Bild 1 von 1
    • Note that there is more adhesive along the top edge and around the camera bezel than around the rest of the phone.
    • Cut carefully around the left edge near the fingerprint sensor or you risk damaging the ribbon cable inside.
    • If, at any point, the adhesive feels stubborn, apply more heat—not more force.
    Frag FixBot
  4. Samsung Galaxy Note9 Iris Scanner Replacement, Slide the opening pick: Schritt 4, Bild 1 von 3 Samsung Galaxy Note9 Iris Scanner Replacement, Slide the opening pick: Schritt 4, Bild 2 von 3 Samsung Galaxy Note9 Iris Scanner Replacement, Slide the opening pick: Schritt 4, Bild 3 von 3
    • Starting from the center, cut the adhesive up and down the right side with an opening pick.
    • Do not insert the pick more than halfway into the phone when cutting near the fingerprint sensor or cameras, or you risk damaging internal components.
    Frag FixBot
  5. Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 5, Bild 3 von 3
    • Be careful near the corner, as the glass is very weak. Apply more heat at any time if the adhesive becomes stuck.
    • Leave an opening pick in the upper-right corner.
    • Use another opening pick to cut the adhesive around the bottom-right corner.
    • Leave that opening pick in the phone.
    Frag FixBot
  6. Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 6, Bild 1 von 1
    • Use a heat gun or hair dryer or apply a heated iOpener to the left side of the rear panel for at three minutes to soften the adhesive underneath.
    Frag FixBot
  7. Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 7, Bild 1 von 3 Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 7, Bild 2 von 3 Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 7, Bild 3 von 3
    • Be careful near the corners, as the glass is weakest there.
    • Insert an opening pick into the lower-left corner of the rear panel.
    • Using another opening pick, cut the adhesive along the left edge of the rear panel.
    • Don't insert an opening pick in more than halfway on the left edge near the fingerprint sensor or you may damage the ribbon cable inside.
    • It is fine if opening picks fall out as the back cover becomes separated.
    Frag FixBot
  8. Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 8, Bild 1 von 3 Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 8, Bild 2 von 3 Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 8, Bild 3 von 3
    • Using the inserted opening pick, carefully cut the adhesive around the upper-left corner of the rear panel.
    • Finally, cut the last of the adhesive along the top of the phone.
    • Use an iOpener, hair dryer, or heat gun to apply more heat as needed where you are cutting the adhesive.
    Frag FixBot
  9. Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 9, Bild 1 von 2 Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 9, Bild 2 von 2
    • Separate the right side of the rear cover first.
    • Tilt the cover up along the left edge to expose the fingerprint sensor ribbon cable.
    • Do not pull out the fingerprint sensor ribbon cable yet.
    • The fingerprint sensor cover might stay attached to the midframe.
    Frag FixBot
  10. Samsung Galaxy Note9 Iris Scanner Replacement, Disconnect the fingerprint sensor: Schritt 10, Bild 1 von 2 Samsung Galaxy Note9 Iris Scanner Replacement, Disconnect the fingerprint sensor: Schritt 10, Bild 2 von 2
    • Use the tip of a spudger to pry the fingerprint sensor ribbon cable up and out of its socket.
    Frag FixBot
  11. Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 11, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Remove the back cover.
    • To re-install the back cover:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive. You don't have to clear out adhesive down to the plastic but larger pieces should be removed.
    • Turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Carefully apply the new adhesive to the back cover, then line up one edge of the glass against the phone chassis and firmly press the glass into the phone.
    Frag FixBot
  12. Achtung: Die Schritte 12-15 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Samsung Galaxy Note9 Iris Scanner Replacement, Remove the upper midframe: Schritt 12, Bild 1 von 2 Samsung Galaxy Note9 Iris Scanner Replacement, Remove the upper midframe: Schritt 12, Bild 2 von 2
    • Use a Phillips screwdriver to remove the nine 4 mm screws securing the upper midframe.
    Frag FixBot
  13. Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 13, Bild 1 von 2 Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 13, Bild 2 von 2
    • Insert the tip of a spudger into the upper-left corner of the upper midframe.
    • Pry the upper midframe out of the phone.
    • The upper midframe snaps into and out of place.
    Frag FixBot
  14. Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 14, Bild 1 von 3 Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 14, Bild 2 von 3 Samsung Galaxy Note9 Iris Scanner Replacement: Schritt 14, Bild 3 von 3
    • Peel the wireless charging coil off the battery starting with the left side.
    • The adhesive is weak but you can use an opening pick to cut it if necessary.
    • During reassembly start by snapping the midframe into place first before adhering the wireless charging coil.
    Frag FixBot
  15. Samsung Galaxy Note9 Iris Scanner Replacement, Disconnect the battery: Schritt 15, Bild 1 von 2 Samsung Galaxy Note9 Iris Scanner Replacement, Disconnect the battery: Schritt 15, Bild 2 von 2
    • Use the tip of a spudger to disconnect the orange ribbon cable connecting the battery to the motherboard.
    Frag FixBot
  16. Samsung Galaxy Note9 Iris Scanner Replacement, Remove the iris scanner: Schritt 16, Bild 1 von 3 Samsung Galaxy Note9 Iris Scanner Replacement, Remove the iris scanner: Schritt 16, Bild 2 von 3 Samsung Galaxy Note9 Iris Scanner Replacement, Remove the iris scanner: Schritt 16, Bild 3 von 3
    • Use the tip of a spudger to pry the iris scanner connector straight up and out of its socket.
    • Use a pair of tweezers to remove the iris scanner.
    Frag FixBot
Abschluss
Sam Omiotek
99.281 Reputation
290 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 40
Insgesamt: 1,403
