Zum Hauptinhalt wechseln
Samsung Galaxy S III Battery Replacement
Was du brauchst
  1. Samsung Galaxy S III Battery Replacement, Rear Case: Schritt 1, Bild 1 von 2 Samsung Galaxy S III Battery Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung Galaxy S III Battery Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy S III Battery Replacement: Schritt 2, Bild 2 von 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
    Frag FixBot
  3. Samsung Galaxy S III Battery Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy S III Battery Replacement: Schritt 3, Bild 2 von 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
    Frag FixBot
  4. Samsung Galaxy S III Battery Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy S III Battery Replacement: Schritt 4, Bild 2 von 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
    Frag FixBot
  5. Samsung Galaxy S III Battery Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy S III Battery Replacement: Schritt 5, Bild 2 von 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
    Frag FixBot
  6. Samsung Galaxy S III Battery Replacement, Battery: Schritt 6, Bild 1 von 2 Samsung Galaxy S III Battery Replacement, Battery: Schritt 6, Bild 2 von 2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
    Frag FixBot
  7. Samsung Galaxy S III Battery Replacement: Schritt 7, Bild 1 von 2 Samsung Galaxy S III Battery Replacement: Schritt 7, Bild 2 von 2
    • Remove the battery.
    Frag FixBot
Abschluss
92 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Do I have to wait after replacing it or can I use my phone right away? If so how long
ivon200021 - Antwort Teilen
Super simple. Thanks!
bmwherry - Antwort Teilen
I don't get it why you insist it takes at least 2 minutes. I've done it in 5 seconds multiple times using fingers and no tabs have ever broken off. It literally takes 5-10 seconds, you just pull it off.
Krzeszny - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 82
Insgesamt: 66,881
