Zum Hauptinhalt wechseln
Samsung Galaxy S5 Battery Replacement
Was du brauchst
  1. Samsung Galaxy S5 Battery Replacement, Rear Case: Schritt 1, Bild 1 von 3 Samsung Galaxy S5 Battery Replacement, Rear Case: Schritt 1, Bild 2 von 3 Samsung Galaxy S5 Battery Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Battery Replacement, Battery: Schritt 2, Bild 1 von 3 Samsung Galaxy S5 Battery Replacement, Battery: Schritt 2, Bild 2 von 3 Samsung Galaxy S5 Battery Replacement, Battery: Schritt 2, Bild 3 von 3
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
Abschluss
83 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Goldheart
465.854 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.198 Anleitungen geschrieben
10 Kommentare
This is too complicated :(
Jaydon - Antwort
Extremely easy
taesusman - Antwort
I replaced the battery in my phone because it drained fast, and drained completely in any temp below 50, I put the new battery In but when I try to turn it on the farthest I get is the screen that says "Samsung galaxy s5" help?
mw - Antwort
Do I also need to remove the sim card? Or can I just put a new battery in?
nancysapone - Antwort
Thanks am replacing glass as well...easy to get the battery and sim out.
rob taylor - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 59
Letzte 30 Tage: 233
Insgesamt: 95,483
