Einleitung
Use this guide to replace the back panel glass on the Samsung Galaxy S8 Plus.
If your replacement part does not come with adhesive mounted on it, you will also need to purchase adhesive for the rear glass and the fingerprint reader. You can buy pre-cut adhesive, or thin high-bond tape.
Was du brauchst
Prepare an iOpener and heat the back of the phone along its left edge for about two minutes. This will help soften the adhesive securing the back cover.
In the following steps, you'll be cutting through the adhesive securing the back cover.
As seen from outside the phone, you'll be slicing through the adhesive in the areas shown:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
Secure a suction cup to the back cover, as close to the heated edge as possible.
Lift the back cover's left edge with your suction cup, opening a slight gap between the back cover and the frame.
Slide your opening pick along the left edge of the phone to slice through the adhesive securing the back cover.
Continue slicing through the adhesive along the bottom edge of the phone.
Again, it may help to leave the opening pick in place and grab another one for the following step.
Use the point of a spudger to pry up and disconnect the fingerprint sensor flex cable.
Then, use the flat end of your spudger to gently snap the connector into place by pressing it straight down.
Remove the back cover.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Reheat an iOpener and apply it to the fingerprint sensor, in order to soften the adhesive securing it to the rear glass.
Push gently but firmly against the fingerprint sensor from the outward-facing side of the glass panel, until the adhesive securing it separates.
If the fingerprint sensor adhesive is intact, it may be reused, but if damaged at all you should remove the old adhesive and apply replacements.
After removing the old adhesive, clean the edges of the fingerprint sensor with high concentration isopropyl alcohol (at least 90%), then apply the new adhesive.
After you've completed the repair, follow this guide to test your repair.
37 weitere Personen haben diese Anleitung absolviert.
17 Kommentare
If I don't have a microwave to heat the iOpener, can i boil it for a few seconds maybe?
I’d highly recommend skipping the iOpener all together and just buy some isopropyl alcohol (found at most Walgreen/RiteAids/Walmarts) and some q-tips instead. Even with the iOpener as hot as they say to get it and hours of letting the heat soak into the adhesive, I still ended up cracking my rear panel glass in the corners, which makes removal even harder/dangerous with shards of glass falling off.
Scott -
@Nick sure, you even can put some noodles while you cook your s8.
If the back is very cracked, it will be a lot harder!
