Einleitung
Is your LCD stuck in place, cracked or unresponsive? Use this guide to remove the LCD assembly and make necessary repairs.
Ersatzteile
Keine Ersatzteile angegeben.
Orient the camera so the button panel and LCD are facing you.
Use a spudger or fingernail to open the battery compartment on the right side of the camera.
Push the blue trapdoor to the left to release the battery, and remove the battery.
Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
Remove the battery compartment.
Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
Use a Phillips #00 screwdriver to remove the two 5 mm screws holding the flash assembly to the camera case.
Remove the 5 mm Phillips #00 screw in the top right corner of the LCD assembly.
Ein weiterer Nutzer hat diese Anleitung absolviert.
