Zum Hauptinhalt wechseln
Samsung Refrigerator Control Board Replacement
Was du brauchst
  1. Samsung Refrigerator Control Board Replacement, Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Control Board Replacement, Remove the board access panel: Schritt 2, Bild 1 von 1
    • Remove the screws securing the board access panel to the back of the refrigerator.
  3. Samsung Refrigerator Control Board Replacement: Schritt 3, Bild 1 von 2 Samsung Refrigerator Control Board Replacement: Schritt 3, Bild 2 von 2
    • Remove the board access panel.
  4. Samsung Refrigerator Control Board Replacement, Reassembly information: Schritt 4, Bild 1 von 2 Samsung Refrigerator Control Board Replacement, Reassembly information: Schritt 4, Bild 2 von 2
    • Note the locations and number of the connectors on the control board, and photograph them or draw a diagram. This example control board has nine wire connectors:
    • Three connectors along the top edge
    • One connector along the right edge
    • One connector along the bottom edge
    • Four connectors along the left edge
    • During reassembly, use your diagram or the photo you took (like the second image here) to make sure you've reconnected all of the connectors.
  5. Samsung Refrigerator Control Board Replacement, Remove the control board: Schritt 5, Bild 1 von 2 Samsung Refrigerator Control Board Replacement, Remove the control board: Schritt 5, Bild 2 von 2
    • Pull and disconnect each of the connectors from the control board.
    • Some connectors may have a locking tab. Squeeze the wide sides of the connector to unlock it, then pull to disconnect it.
    • Move the wires away from the control board so it can swing out of its recess.
  6. Samsung Refrigerator Control Board Replacement: Schritt 6, Bild 1 von 3 Samsung Refrigerator Control Board Replacement: Schritt 6, Bild 2 von 3 Samsung Refrigerator Control Board Replacement: Schritt 6, Bild 3 von 3
    • Use your fingers to push up the plastic lip securing the top edge of the control board to the refrigerator.
    • Swing the control board out and remove it.
Abschluss
Repair didn’t go as planned? Ask our Answers Community for help.
2 weitere Personen haben diese Anleitung absolviert.
Bill Gilbert
38.494 Reputation
261 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
23.608 Anleitungen geschrieben
5 Kommentare zur Anleitung
My tempura in my new refrigerator isn’t working right , I bought earlier this year
Carolyn whittaker - Antwort
Do you have a phone number
Samsung fridge- after changing a water filter, bottom drawer freezer stopped making ice.
It is set for 0 but no ice. I bought this fridge last year.
Sewell Nikki - Antwort
My refrigerator light is on but the comppresor is not working and anytime I on it is not piping sounds again
Asiafa - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 64
Letzte 30 Tage: 255
Insgesamt: 6,416
