Zum Hauptinhalt wechseln
Samsung Rogue Front Function Keys Replacement
Was du brauchst
  1. Samsung Rogue Front Function Keys Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Rogue Front Function Keys Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung Rogue Front Function Keys Replacement: Schritt 2, Bild 1 von 2 Samsung Rogue Front Function Keys Replacement: Schritt 2, Bild 2 von 2
    • You can now remove the battery by prying it up with your finger.
    Frag FixBot
  3. Samsung Rogue Front Function Keys Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
    Frag FixBot
  4. Samsung Rogue Front Function Keys Replacement: Schritt 4, Bild 1 von 1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
    Frag FixBot
  5. Samsung Rogue Front Function Keys Replacement: Schritt 5, Bild 1 von 3 Samsung Rogue Front Function Keys Replacement: Schritt 5, Bild 2 von 3 Samsung Rogue Front Function Keys Replacement: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
    Frag FixBot
  6. Samsung Rogue Front Function Keys Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 3.45 mm Philips screws below the white sticker.
    Frag FixBot
  7. Samsung Rogue Front Function Keys Replacement: Schritt 7, Bild 1 von 2 Samsung Rogue Front Function Keys Replacement: Schritt 7, Bild 2 von 2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
    Frag FixBot
  8. Samsung Rogue Front Function Keys Replacement: Schritt 8, Bild 1 von 2 Samsung Rogue Front Function Keys Replacement: Schritt 8, Bild 2 von 2
    • Use a plastic opening tool to disconnect the film from the motherboard.
    Frag FixBot
  9. Samsung Rogue Front Function Keys Replacement, Front Function Keys: Schritt 9, Bild 1 von 1
    • Remove the eight 1.7mm Philips screws above the keyboard.
    Frag FixBot
  10. Samsung Rogue Front Function Keys Replacement: Schritt 10, Bild 1 von 1
    • Carefully remove keyboard frame from the sliding mechanisms underneath.
    Frag FixBot
  11. Samsung Rogue Front Function Keys Replacement: Schritt 11, Bild 1 von 1
    • Remove the five 3.0mm Philips screws around the outside of the sliding mechanisms.
    Frag FixBot
  12. Samsung Rogue Front Function Keys Replacement: Schritt 12, Bild 1 von 3 Samsung Rogue Front Function Keys Replacement: Schritt 12, Bild 2 von 3 Samsung Rogue Front Function Keys Replacement: Schritt 12, Bild 3 von 3
    • Use a plastic opening tool to pry off the upper slide plate.
    • Be careful of the film of wires when taking off the upper slide plate.
    Frag FixBot
  13. Samsung Rogue Front Function Keys Replacement: Schritt 13, Bild 1 von 3 Samsung Rogue Front Function Keys Replacement: Schritt 13, Bild 2 von 3 Samsung Rogue Front Function Keys Replacement: Schritt 13, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to open the two black gates by putting them in the "up" position.
    • With the same tweezers, carefully pull out the orange strips from the two specified gates.
    Frag FixBot
  14. Samsung Rogue Front Function Keys Replacement: Schritt 14, Bild 1 von 3 Samsung Rogue Front Function Keys Replacement: Schritt 14, Bild 2 von 3 Samsung Rogue Front Function Keys Replacement: Schritt 14, Bild 3 von 3
    • Using tweezers, gently remove the bottom orange strip from the device.
    • At this point you can easily lift out the rubber function key pad as well.
    Frag FixBot
  15. Samsung Rogue Front Function Keys Replacement: Schritt 15, Bild 1 von 3 Samsung Rogue Front Function Keys Replacement: Schritt 15, Bild 2 von 3 Samsung Rogue Front Function Keys Replacement: Schritt 15, Bild 3 von 3
    • There are two ways you can take out the front function keys:
    • 1) Use a plastic phone opening tool to pry out the piece from the front of the phone.
    • 2) Simply pop out the piece from the inside by pushing on its tabs.
    Frag FixBot
Abschluss
Cal Poly, Team 7-32, Maness Spring 2012 Mitglied von Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Mitglieder
36 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 32
Insgesamt: 730
