Zum Hauptinhalt wechseln
Samsung SPEX SCH-R210 Keypad Replacement
Was du brauchst
  1. Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: Schritt 1, Bild 1 von 3 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: Schritt 1, Bild 2 von 3 Samsung SPEX SCH-R210 Keypad Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung SPEX SCH-R210 Keypad Replacement, Battery: Schritt 2, Bild 1 von 1
    • Locate the access notch at the end of the battery compartment.
    Frag FixBot
  3. Samsung SPEX SCH-R210 Keypad Replacement: Schritt 3, Bild 1 von 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
    Frag FixBot
  4. Samsung SPEX SCH-R210 Keypad Replacement, Keypad: Schritt 4, Bild 1 von 2 Samsung SPEX SCH-R210 Keypad Replacement, Keypad: Schritt 4, Bild 2 von 2
    • Remove the four 4.8 mm screws from the midframe using a Phillips #00 screwdriver.
    Frag FixBot
  5. Samsung SPEX SCH-R210 Keypad Replacement: Schritt 5, Bild 1 von 1
    • Remove the headphone cover from the left side of the midframe.
    Frag FixBot
  6. Samsung SPEX SCH-R210 Keypad Replacement: Schritt 6, Bild 1 von 1
    • Remove the volume cover from the right side of the midframe.
    Frag FixBot
  7. Samsung SPEX SCH-R210 Keypad Replacement: Schritt 7, Bild 1 von 1
    • Use your hands to separate the midframe from the rest of the phone.
    • This may take a little effort to remove.
    Frag FixBot
  8. Samsung SPEX SCH-R210 Keypad Replacement: Schritt 8, Bild 1 von 1
    • Use a 1.5 mm hex screwdriver to remove the three 2.4 mm screws around the motherboard.
    Frag FixBot
  9. Samsung SPEX SCH-R210 Keypad Replacement: Schritt 9, Bild 1 von 1
    • Lift the metal plate off of the motherboard and set it aside.
    Frag FixBot
  10. Samsung SPEX SCH-R210 Keypad Replacement: Schritt 10, Bild 1 von 2 Samsung SPEX SCH-R210 Keypad Replacement: Schritt 10, Bild 2 von 2
    • Push on the white plastic tabs and the keypad at the same time to remove the motherboard.
    Frag FixBot
  11. Samsung SPEX SCH-R210 Keypad Replacement: Schritt 11, Bild 1 von 2 Samsung SPEX SCH-R210 Keypad Replacement: Schritt 11, Bild 2 von 2
    • Turn the phone over to its front side.
    • Apply pressure on the keypad.
    • The keypad will come out easily.
    Frag FixBot
Abschluss
Susan
331 Reputation
3 Anleitungen geschrieben
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Mitglied von WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Mitglieder
20 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 35
Insgesamt: 647
