Zum Hauptinhalt wechseln
Samsung SPEX SCH-R210 antenna Replacement
Was du brauchst
    1. Samsung SPEX SCH-R210 antenna Replacement, Back Cover: Schritt 1, Bild 1 von 3 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: Schritt 1, Bild 2 von 3 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: Schritt 1, Bild 3 von 3
      • Lay the phone on its front side so the back is visible.
      • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
      • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
      • Slide the cover down from the phone to remove it. Set the cover aside.
      Frag FixBot
      Kommentar hinzufügen
    1. Samsung SPEX SCH-R210 antenna Replacement, Battery: Schritt 2, Bild 1 von 1
      • Locate the access notch at the end of the battery compartment.
      Frag FixBot
    2. Samsung SPEX SCH-R210 antenna Replacement: Schritt 3, Bild 1 von 1
      • Place your thumb on the edge of the battery near the access notch.
      • Lift the battery to remove it from the phone. Set the battery aside.
      Frag FixBot
    1. Samsung SPEX SCH-R210 antenna Replacement, Antenna: Schritt 4, Bild 1 von 2 Samsung SPEX SCH-R210 antenna Replacement, Antenna: Schritt 4, Bild 2 von 2
      • After removing the battery, unscrew the 4 3/16" screws on the black plastic cover with the Phillips #00 screwdriver.
      Frag FixBot
    2. Samsung SPEX SCH-R210 antenna Replacement: Schritt 5, Bild 1 von 2 Samsung SPEX SCH-R210 antenna Replacement: Schritt 5, Bild 2 von 2
      • Remove the headphone cover from the left side and the volume cover from the right side of the phone.
      Frag FixBot
    3. Samsung SPEX SCH-R210 antenna Replacement: Schritt 6, Bild 1 von 1
      • Remove the black plastic cover from the back of the phone. This may take a little effort to remove.
      Frag FixBot
    4. Samsung SPEX SCH-R210 antenna Replacement: Schritt 7, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • The antenna is located on the opposite side of the black plastic cover. Use the tweezers to remove the antenna.
      Frag FixBot
    5. Samsung SPEX SCH-R210 antenna Replacement: Schritt 8, Bild 1 von 1
      • The gray rubber antenna cover will need to come out as well. Use the tweezers to remove the gray cover.
      Frag FixBot
    6. Samsung SPEX SCH-R210 antenna Replacement: Schritt 9, Bild 1 von 1
      • Replace with a new antenna.
      Frag FixBot
Abschluss
Susan
331 Reputation
3 Anleitungen geschrieben
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Mitglied von WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Mitglieder
20 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 550
