Zum Hauptinhalt wechseln
Skullcandy Crusher Wireless Battery Replacement
Was du brauchst
  1. Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: Schritt 1, Bild 1 von 2 Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: Schritt 1, Bild 2 von 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Battery Replacement: Schritt 2, Bild 1 von 2 Skullcandy Crusher Wireless Battery Replacement: Schritt 2, Bild 2 von 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Battery Replacement: Schritt 3, Bild 1 von 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Skullcandy Crusher Wireless Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
    • You have to work on the right-side earphone.
  5. Skullcandy Crusher Wireless Battery Replacement: Schritt 5, Bild 1 von 3 Skullcandy Crusher Wireless Battery Replacement: Schritt 5, Bild 2 von 3 Skullcandy Crusher Wireless Battery Replacement: Schritt 5, Bild 3 von 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker part away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Battery Replacement: Schritt 6, Bild 1 von 2 Skullcandy Crusher Wireless Battery Replacement: Schritt 6, Bild 2 von 2
    • Separate the headphone speaker assembly from the headphone speaker frame.
  7. Skullcandy Crusher Wireless Battery Replacement: Schritt 7, Bild 1 von 3 Skullcandy Crusher Wireless Battery Replacement: Schritt 7, Bild 2 von 3 Skullcandy Crusher Wireless Battery Replacement: Schritt 7, Bild 3 von 3
    • Remove the battery from the headphone housing.
    • Use a soldering iron to desolder the black, red, and yellow cables from the board and disconnect the battery.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Val
1.104 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 Mitglied von UMass Dartmouth, Team 1-33, Gurgel Spring 2022
UMASSD-GURGEL-S22S1G33
1 Mitglied
12 Anleitungen geschrieben
4 Kommentare
Hi, Can you specify this replacement batterys name and model number?
kituserkituserkituser kit - Antwort
1050mAh, 3,7V 3,885Wh
Mika Björn Wilhelmsen -
Which battery should i buy for my skull candy hes evo??
Lakshit Meena - Antwort
donde puedo conseguir la bateria de los skullcandy crusher?
y cual bateria lleva?
pedro landeros - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 54
Letzte 30 Tage: 295
Insgesamt: 9,075
