Einleitung
Use this guide to replace the battery in a Skullcandy Crusher Wireless headphones. A replacement battery can be bought online.
Follow this replacement guide if you've identified the battery as a source of the problem (or maybe you just want to see the internal components of your Skullcandy Crusher Wireless). To be sure, check out the Troubleshooting page.
Make sure you are not working with a swollen battery.
Also, for more information about soldering and desoldering, please use this guide.
Was du brauchst
Take your headphones and hold them upside down for better control with your hands.
Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
Gently pry the speaker part away from the frame of the headphones.
Remove the battery from the headphone housing.
Use a soldering iron to desolder the black, red, and yellow cables from the board and disconnect the battery.
4 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
Hi, Can you specify this replacement batterys name and model number?
1050mAh, 3,7V 3,885Wh
Which battery should i buy for my skull candy hes evo??
donde puedo conseguir la bateria de los skullcandy crusher?
y cual bateria lleva?
