Zum Hauptinhalt wechseln
Skullcandy Crusher Wireless Bluetooth Antenna Replacement
Was du brauchst
  1. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: Schritt 1, Bild 1 von 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: Schritt 1, Bild 2 von 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: Schritt 2, Bild 1 von 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: Schritt 2, Bild 2 von 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: Schritt 3, Bild 1 von 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: Schritt 4, Bild 1 von 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: Schritt 4, Bild 2 von 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
  5. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: Schritt 5, Bild 1 von 3 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: Schritt 5, Bild 2 von 3 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: Schritt 5, Bild 3 von 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker assembly away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: Schritt 6, Bild 1 von 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: Schritt 6, Bild 2 von 2
    • Separate headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: Schritt 7, Bild 1 von 1
    • The Bluetooth antenna module chip is located on the right top corner of the motherboard.
    • If necessary, the chip module can be desoldered and replaced with a new one. Or, the motherboard can be replaced.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Val
1.104 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 Mitglied von UMass Dartmouth, Team 1-33, Gurgel Spring 2022
UMASSD-GURGEL-S22S1G33
1 Mitglied
12 Anleitungen geschrieben
Ein Kommentar
Where can one purchase a replacement chip?
Josh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 51
Insgesamt: 1,024
