Zum Hauptinhalt wechseln
Solio CLASSIC2 Battery Replacement
Was du brauchst
    1. Solio CLASSIC2 Battery Replacement, Disconnecting the Battery: Schritt 1, Bild 1 von 1
      • Turn off the device by pressing on the clear power button behind the device.
      • To make sure that it is off, make sure the button is not flashing green.
      Frag FixBot
      Kommentar hinzufügen
    2. Solio CLASSIC2 Battery Replacement: Schritt 2, Bild 1 von 1
      • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
      Frag FixBot
    3. Solio CLASSIC2 Battery Replacement: Schritt 3, Bild 1 von 3 Solio CLASSIC2 Battery Replacement: Schritt 3, Bild 2 von 3 Solio CLASSIC2 Battery Replacement: Schritt 3, Bild 3 von 3
      • Using the plastic opening tools, gently pry open the side of the large panel.
      • Keeping the tool in, slowly slide the tool along the side of the panel.
      Frag FixBot
    4. Solio CLASSIC2 Battery Replacement: Schritt 4, Bild 1 von 2 Solio CLASSIC2 Battery Replacement: Schritt 4, Bild 2 von 2
      • Rotate the device 180 degrees.
      • Make sure the opening on other side of the device does not snap closed.
      • Gently slide the plastic opening tool along the side of the panel.
      Frag FixBot
    5. Solio CLASSIC2 Battery Replacement: Schritt 5, Bild 1 von 2 Solio CLASSIC2 Battery Replacement: Schritt 5, Bild 2 von 2
      • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
      • Using both hands, slowly pull apart the back panel from the rest of the device.
      • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
      Frag FixBot
    6. Solio CLASSIC2 Battery Replacement: Schritt 6, Bild 1 von 2 Solio CLASSIC2 Battery Replacement: Schritt 6, Bild 2 von 2
      • Softly pinch the red and blue wires close to the white connector.
      • To pull the wires out, wiggle them back and forth until the connector is fully out.
      Frag FixBot
    1. Solio CLASSIC2 Battery Replacement, Circuit Board: Schritt 7, Bild 1 von 1
      • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
      Frag FixBot
    2. Solio CLASSIC2 Battery Replacement: Schritt 8, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
      • Gently lift the circuit board out of the device using tweezers.
      Frag FixBot
    1. Solio CLASSIC2 Battery Replacement, Battery: Schritt 9, Bild 1 von 1
      • Remove the two 2mm screws from the battery case.
      Frag FixBot
    2. Solio CLASSIC2 Battery Replacement: Schritt 10, Bild 1 von 1
      • Gently pull up the battery case out of the tabs and pull the case out.
      Frag FixBot
    3. Solio CLASSIC2 Battery Replacement: Schritt 11, Bild 1 von 1
      • Gently lift up the battery.
      Frag FixBot
Abschluss
Cal Poly, Team 4-28, Amido Fall 2013 Mitglied von Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 34
Insgesamt: 1,763
