Zum Hauptinhalt wechseln
Sony DSC-RX10M3 Back and Right Panel Replacement
Was du brauchst
    1. Sony DSC-RX10M3 Back and Right Panel Replacement, Battery Replacement: Schritt 1, Bild 1 von 1
      • Turn off the Device by scrolling the tab to "OFF" indicated by the arrow.
      Frag FixBot
      Kommentar hinzufügen
    2. Sony DSC-RX10M3 Back and Right Panel Replacement: Schritt 2, Bild 1 von 3 Sony DSC-RX10M3 Back and Right Panel Replacement: Schritt 2, Bild 2 von 3 Sony DSC-RX10M3 Back and Right Panel Replacement: Schritt 2, Bild 3 von 3
      • Remove the battery located at the bottom of the device.
      Frag FixBot
    1. Sony DSC-RX10M3 Back and Right Panel Replacement, Back and Right Panel: Schritt 3, Bild 1 von 1
      • Remove the twelve 0.7mm Phillips #000 screws from the bottom case.
      Frag FixBot
    2. Sony DSC-RX10M3 Back and Right Panel Replacement: Schritt 4, Bild 1 von 2 Sony DSC-RX10M3 Back and Right Panel Replacement: Schritt 4, Bild 2 von 2
      • Remove the two 0.7mm screws that secure the right side of the camera.
      • Remove the two 0.7mm screws that secure the left side of the camera, near the Wi-Fi logo and charging port.
      Frag FixBot
    3. Sony DSC-RX10M3 Back and Right Panel Replacement: Schritt 5, Bild 1 von 2 Sony DSC-RX10M3 Back and Right Panel Replacement: Schritt 5, Bild 2 von 2
      • Gently pull off the plastic eye guard.
      Frag FixBot
    4. Sony DSC-RX10M3 Back and Right Panel Replacement: Schritt 6, Bild 1 von 2 Sony DSC-RX10M3 Back and Right Panel Replacement: Schritt 6, Bild 2 von 2
      • Use a Phillips #000 screwdriver to remove the four 0.4mm screws located under the rubber eye guard.
      • Use a plastic opening tool to detach the back panel of the camera.
      Frag FixBot
    5. Sony DSC-RX10M3 Back and Right Panel Replacement: Schritt 7, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • This is a tight spot; make sure you use minimal force when removing the cover.
      • Using tweezers, disconnect the ribbon cable connecting the LCD to the circuit board.
      Frag FixBot
    6. Sony DSC-RX10M3 Back and Right Panel Replacement: Schritt 8, Bild 1 von 1
      • This step is only needed if you wish to remove the right side panel.
      • Use a plastic openeing tool to gently detach the right panel.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
York University, Team S4-G4, Woodhouse Winter 2020 Mitglied von York University, Team S4-G4, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S4G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 74
Insgesamt: 1,984
