Zum Hauptinhalt wechseln
Sony PlayStation Camera Microphone Array Replacement
Was du brauchst
  1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: Schritt 1, Bild 1 von 2 Sony PlayStation Camera Microphone Array Replacement, Microphone Array: Schritt 1, Bild 2 von 2
    • Separate the camera from the camera stand to gain access to the bottom of the camera.
    Frag FixBot
    Kommentar hinzufügen
  2. Sony PlayStation Camera Microphone Array Replacement: Schritt 2, Bild 1 von 2 Sony PlayStation Camera Microphone Array Replacement: Schritt 2, Bild 2 von 2
    • With the PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
    Frag FixBot
  3. Sony PlayStation Camera Microphone Array Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, remove the cap holding the cable grommet in place.
    Frag FixBot
  4. Sony PlayStation Camera Microphone Array Replacement: Schritt 4, Bild 1 von 1
    • Using the tweezers, remove both poly-carbonate lens coverplates.
    • Lift the coverplates slowly, to ensure they do not crack, or break.
    Frag FixBot
  5. Sony PlayStation Camera Microphone Array Replacement: Schritt 5, Bild 1 von 2 Sony PlayStation Camera Microphone Array Replacement: Schritt 5, Bild 2 von 2
    • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
    Frag FixBot
  6. Sony PlayStation Camera Microphone Array Replacement: Schritt 6, Bild 1 von 1
    • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
    • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
    Frag FixBot
  7. Sony PlayStation Camera Microphone Array Replacement: Schritt 7, Bild 1 von 2 Sony PlayStation Camera Microphone Array Replacement: Schritt 7, Bild 2 von 2
    • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
    Frag FixBot
  8. Sony PlayStation Camera Microphone Array Replacement: Schritt 8, Bild 1 von 3 Sony PlayStation Camera Microphone Array Replacement: Schritt 8, Bild 2 von 3 Sony PlayStation Camera Microphone Array Replacement: Schritt 8, Bild 3 von 3
    • Lift the motherboard and frame from the plastic housing.
    • Disconnect the camera cable from the motherboard.
    Frag FixBot
  9. Sony PlayStation Camera Microphone Array Replacement: Schritt 9, Bild 1 von 2 Sony PlayStation Camera Microphone Array Replacement: Schritt 9, Bild 2 von 2
    • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
    Frag FixBot
  10. Sony PlayStation Camera Microphone Array Replacement: Schritt 10, Bild 1 von 2 Sony PlayStation Camera Microphone Array Replacement: Schritt 10, Bild 2 von 2
    • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
    Frag FixBot
  11. Sony PlayStation Camera Microphone Array Replacement: Schritt 11, Bild 1 von 3 Sony PlayStation Camera Microphone Array Replacement: Schritt 11, Bild 2 von 3 Sony PlayStation Camera Microphone Array Replacement: Schritt 11, Bild 3 von 3
    • Using fine point tweezers, grab hold of each microphone, one at a time, and lift from the plastic frame.
    • Using care to not damage the wires, remove microphone array from the retaining tabs on the plastic frame.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 5-5, Passmore Spring 2017 Mitglied von USF Tampa, Team 5-5, Passmore Spring 2017
USFT-PASSMORE-S17S5G5
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 68
Insgesamt: 7,794
