Einleitung
Follow this guide to replace the ear pads on the Sony WH-1000XM4 wireless headphones.
Note: The left and right ear pads are different on this model.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Place your headphones onto a work surface, ear pads facing up.
Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame.
Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
Pivot the spudger down to unclip the long edge of the ear pad.
Repeat the previous step around the perimeter of the ear cup to disconnect the remaining clips.
Align the cushion over the speaker and press them firmly together to snap it into place.
Press around the entire edge of the cushion, making sure all the clips have engaged.
Use your thumb to depress the RIGHT ear pad near the long outer edge, creating a gap between the cushion and the frame.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
3 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
This is a great guide!
it is also the solution to the ticking problem on the left ear cup!
there is a small cable linking the microphone to the headset that is beneath the earcup. it has a small holder that should prevent it from moving.
if it’s not attached properly, the noise canceling will start ticking every few seconds in a very annoying way.
removing the earcup and cleaning there is the best solution I found!
Thanks a lot for the amazing guide!!
