Einleitung
Is your sharpener not working at all? Does it seem to be "dead"? Then you may need to follow these steps to replace the A/C motor on your Staples 34462 Electric Pencil Sharpener. See our troubleshooting guide for more information on this problem. Note that some soldering may be necessary to complete the steps in this guide. See iFixit's soldering guide for more tips and help on how to best accomplish this step.
Was du brauchst
Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
Using the plastic opening tool, remove the back plastic feet.
After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
Using a Philips 00 screwdriver, remove the first 10.3mm screw attaching the A/C motor to the panel.
Gently pry the gear from the panel with a spudger to expose the second screw holding the electric A/C motor to the panel.
Using a Philips 00 screwdriver, remove the second 10.3mm screw securing the electric A/C motor to the panel.
Using a soldering iron, carefully de-solder the two wires from the electric A/C motor.
Eine weitere Person hat diese Anleitung absolviert.
