Zum Hauptinhalt wechseln
Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement
Was du brauchst
  1. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: Schritt 1, Bild 1 von 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: Schritt 1, Bild 2 von 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: Schritt 1, Bild 3 von 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: Schritt 2, Bild 1 von 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: Schritt 4, Bild 1 von 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: Schritt 4, Bild 2 von 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: Schritt 4, Bild 3 von 3
    • Facing the inside of the front of the case, release the white ribbon cable by pulling the black rectangular connector at the end of the connection
    • Once the black holder is opened, gently pull the cable out of the holder.
  5. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: Schritt 5, Bild 1 von 1
    • Facing the back of the small board, remove the two 2.0 mm Phillips #0 black screws that connect it to the back of the case.
  6. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: Schritt 6, Bild 1 von 1
    • Carefully use a soldering iron to melt the solder in three places that connect the motion sensor. For more information on soldering follow this helpful guide.
    • Pull the sensor out from the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 18
Insgesamt: 379
