Zum Hauptinhalt wechseln
Tagital T10 Camera Replacement
Was du brauchst
    1. Tagital T10 Camera Replacement, Camera: Schritt 1, Bild 1 von 1
      • Always make sure your device is completely powered off before performing repairs.
      • Remove the two 4 mm Phillips head screws at the top of the device.
      Frag FixBot
      Kommentar hinzufügen
    2. Tagital T10 Camera Replacement: Schritt 2, Bild 1 von 1
      • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
      • Set the back cover aside.
      • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Be careful not to rip these free when removing the back.
      Frag FixBot
    3. Tagital T10 Camera Replacement: Schritt 3, Bild 1 von 1
      • Pull the black tape away so that the rear-facing camera is no longer attached to the device.
      Frag FixBot
    4. Tagital T10 Camera Replacement: Schritt 4, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • Pull off the plastic camera cover with the tweezers so that the front-facing camera can move freely.
      Frag FixBot
    5. Tagital T10 Camera Replacement: Schritt 5, Bild 1 von 1
      • Locate the small ZIF connector that connects to the cameras.
      • Use the plastic prying tool to pull up the black tab, so that the filament is released. Carefully pull the filament out so it is moving freely.
      • The camera can now be lifted from the device.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 14-5, Eyestone Fall 2016 Mitglied von USF Tampa, Team 14-5, Eyestone Fall 2016
USFT-EYESTONE-F16S14G5
4 Mitglieder
25 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 42
Insgesamt: 533
