Zum Hauptinhalt wechseln
Titan Airless Sprayer IMPACT 410 Capacitor Replacement
Was du brauchst
  1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: Schritt 1, Bild 1 von 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: Schritt 1, Bild 2 von 2
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: Schritt 2, Bild 1 von 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: Schritt 2, Bild 2 von 2
    • Use a Phillips driver to remove the four 12 mm-long screws (two on either side) securing the motor cover.
  3. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: Schritt 3, Bild 1 von 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: Schritt 3, Bild 2 von 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: Schritt 3, Bild 3 von 3
    • Pull the motor cover straight off the motor.
  4. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: Schritt 4, Bild 1 von 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: Schritt 4, Bild 2 von 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: Schritt 4, Bild 3 von 3
    • Use diagonal cutters, or scissors, to cut the two cable ties bundling the capacitor's positive and negative wires.
    • During reassembly, replace the cable ties.
  5. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: Schritt 5, Bild 1 von 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: Schritt 5, Bild 2 von 2
    • Disconnect the black negative wire's spade connector.
    • Always grip cables by their connectors and not the wires themselves.
  6. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: Schritt 6, Bild 1 von 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: Schritt 6, Bild 2 von 2
    • Disconnect the red positive wire's bullet connector.
  7. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: Schritt 7, Bild 1 von 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: Schritt 7, Bild 2 von 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: Schritt 7, Bild 3 von 3
    • Grip the cable tie and slide it off the capacitors.
  8. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Discharge the capacitors: Schritt 8, Bild 1 von 1
    • If you have already discharged the capacitors, skip this step.
    • Follow this guide to discharge your capacitors.
  9. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: Schritt 9, Bild 1 von 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: Schritt 9, Bild 2 von 2
    • The capacitors are lightly adhered to the motor body.
    • Insert a flathead screwdriver underneath the capacitors, between the bottom cell and the adhesive.
    • Pry up to separate the bottom cell from the motor body.
  10. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: Schritt 10, Bild 1 von 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: Schritt 10, Bild 2 von 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: Schritt 10, Bild 3 von 3
    • Insert a flathead screwdriver underneath the capacitors, between the top cell and the adhesive.
    • Pry up to separate the rest of the capacitor from the motor body.
    • Remove the capacitor.
    • During reassembly, if the adhesive is no longer sticky, replace it with double-sided foam adhesive.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Alex Diaz-Kokaisl
161.942 Reputation
769 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.410 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 411
