Zum Hauptinhalt wechseln
TomTom One XL Power Button Replacement
Was du brauchst
    1. TomTom One XL Power Button Replacement, Back Panel: Schritt 1, Bild 1 von 2 TomTom One XL Power Button Replacement, Back Panel: Schritt 1, Bild 2 von 2
      • Remove the 4 .4mm screws on the back of the device.
      Frag FixBot
      Kommentar hinzufügen
    2. TomTom One XL Power Button Replacement: Schritt 2, Bild 1 von 1
      • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
      • You can rotate TOMTOM XL to make prying back off easier.
      • Be careful not to injure the two wires connecting the pieces.
      Frag FixBot
    3. TomTom One XL Power Button Replacement: Schritt 3, Bild 1 von 1
      • After prying both halves apart, they will be connected by two wires.
      • Carefully set the two halves next to each other making sure not to stress or damage the wires.
      Frag FixBot
    4. TomTom One XL Power Button Replacement: Schritt 4, Bild 1 von 2 TomTom One XL Power Button Replacement: Schritt 4, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
      • Be gentle while pulling the wires out, the plugs are easily injured.
      Frag FixBot
    1. TomTom One XL Power Button Replacement, Power Button: Schritt 5, Bild 1 von 1
      • Using a Torx 6 screwdriver, remove the 4 .5mm screws connecting the motherboard to the screen assembly.
      • The motherboard is connected to the screen assembly via a ribbon wire. After removing the screws, be careful not to damage the wire or the port.
      Frag FixBot
    2. TomTom One XL Power Button Replacement: Schritt 6, Bild 1 von 2 TomTom One XL Power Button Replacement: Schritt 6, Bild 2 von 2
      • Detach the ribbon wire from it's port on the back of the motherboard.
      Frag FixBot
    3. TomTom One XL Power Button Replacement: Schritt 7, Bild 1 von 3 TomTom One XL Power Button Replacement: Schritt 7, Bild 2 von 3 TomTom One XL Power Button Replacement: Schritt 7, Bild 3 von 3
      • Now the power button is exposed and any obstructions can be easily removed.
      • If you want to replace the button it can easily be popped out using your hands.
      Frag FixBot
Abschluss
Colorado Springs, Team 9-6, Panko Spring 2015 Mitglied von Colorado Springs, Team 9-6, Panko Spring 2015
UCCS-PANKO-S15S9G6
3 Mitglieder
15 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 9
Letzte 30 Tage: 28
Insgesamt: 2,609
