Zum Hauptinhalt wechseln
TopTro TR23 Focus Motor Replacement
Was du brauchst
  1. TopTro TR23 Focus Motor Replacement, Case: Schritt 1, Bild 1 von 3 TopTro TR23 Focus Motor Replacement, Case: Schritt 1, Bild 2 von 3 TopTro TR23 Focus Motor Replacement, Case: Schritt 1, Bild 3 von 3
    • Set the projector on its side so the the front is facing to your left.
    • Insert an opening tool into the seam between the black chassis and the silver case.
    • Pry around the perimeter until the case fully releases.
    • When removing the cover, be careful as there is an internal connector attached to the lid and the projectors motherboard. You’ll have to carefully detach that before fully removing the projector case.
    • Remove the case.
  2. TopTro TR23 Focus Motor Replacement, Focus Motor: Schritt 2, Bild 1 von 3 TopTro TR23 Focus Motor Replacement, Focus Motor: Schritt 2, Bild 2 von 3 TopTro TR23 Focus Motor Replacement, Focus Motor: Schritt 2, Bild 3 von 3
    • Remove both of the 5.5 mm screws with a Phillips #1 screwdriver.
  3. TopTro TR23 Focus Motor Replacement: Schritt 3, Bild 1 von 2 TopTro TR23 Focus Motor Replacement: Schritt 3, Bild 2 von 2
    • Use your fingernails to gently disconnect the motor connector from its motherboard socket.
    • Remove the focus motor.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Francisco
85 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 51
