Einleitung
This guide shows how to remove and replace the tub for the Toro Cement Mixer 68009HD.
Warning: The tub is extremely heavy and requires at least two people to lift it. Be sure to practice safe lifting techniques.
Was du brauchst
Before you begin, press the engine-stop switch to turn off the engine.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Fast fertig!
Abschluss
