Einleitung
Follow this guide to remove the back cover of the Toshiba L55 laptop. This requires partially removing the DVD SuperMultiDrive, as a metal tab is trapped underneath it.
Was du brauchst
Flip the laptop over so that the back cover is facing up.
Unscrew the captive Phillips screw securing the RAM cover.
Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
Disconnect the cable.
Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
Insert the point of an opening pick in the seam between the SuperMultiDrive and the rest of the back cover.
Push the SuperMultiDrive's lip away from the back cover to disconnect the drive.
Slide the drive out of the bay and remove it from the laptop.
Insert the point of an opening pick into the back cover seam near the ethernet port.
Twist the pick to release the plastic clips along the edge.
Grasp the loosened back case edge with your hand and lift it slowly away from the laptop. The remaining clips should release with ease.
Remove the back cover.
