Einleitung
When the battery is dead or unable to hold a charge it is time to replace it with a new one. This guide will walk you through the steps to do so. To be safe in removing the other components you need to remove the batter to prevent damage to the laptop.
Was du brauchst
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Eine weitere Person hat diese Anleitung absolviert.
