Einleitung
If you are having issues with your Trio Stealth Pro 9.7" and find the motherboard needs to be replaced, whether it be malfunctioning or outdated, you can use this guide to achieve this goal.
The motherboard is a vital piece of any computer. It is in charge of many things, including distributing energy from the power supply and facilitates communication between the various hardware components.
Signs of a faulty motherboard can include failing to boot, random shutdowns or freezes, overheating, strange noises, and a burning smell.
Be sure the device is fully shut off before beginning the repair. For putting a new motherboard in, you may find you need to solder the cut wires.
Was du brauchst
Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
Unclip large orange flex cable.
Use plastic opening tool to lift open black clip where the flex cables are attached to the motherboard.
Then gently pull out the flex cable with tweezers.
Remove flex cable clip in top left area of motherboard.
Use plastic opening tool to lift open black clip where the flex cables are attached to the motherboard. gently pull out the flex cable with tweezers.
Cut red black and gray wires attached to the bottom of the motherboard connecting to the battery.
Cut three red and three black wires attached to the right side of the motherboard.
Cut 4 wire cable attached to the right side of the motherboard.
Remove motherboard.
2 weitere Personen haben diese Anleitung absolviert.
