Zum Hauptinhalt wechseln
Turtle Beach REACT-R Bumpers Replacement
Was du brauchst
  1. Turtle Beach REACT-R Bumpers Replacement, Rear Case: Schritt 1, Bild 1 von 3 Turtle Beach REACT-R Bumpers Replacement, Rear Case: Schritt 1, Bild 2 von 3 Turtle Beach REACT-R Bumpers Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Place the controller face down.
    • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
    • Use both hands to lift the backplate away from the controller.
    Frag FixBot
    Kommentar hinzufügen
  2. Turtle Beach REACT-R Bumpers Replacement, Motherboard: Schritt 2, Bild 1 von 3 Turtle Beach REACT-R Bumpers Replacement, Motherboard: Schritt 2, Bild 2 von 3 Turtle Beach REACT-R Bumpers Replacement, Motherboard: Schritt 2, Bild 3 von 3
    • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
    • Two of the screws are hidden under the red and black vibration motor wires.
    • Gently lift the motherboard up and out of the chassis.
    • Be careful not to strain the vibration motor wires.
    Frag FixBot
  3. Turtle Beach REACT-R Bumpers Replacement, Bumpers: Schritt 3, Bild 1 von 3 Turtle Beach REACT-R Bumpers Replacement, Bumpers: Schritt 3, Bild 2 von 3 Turtle Beach REACT-R Bumpers Replacement, Bumpers: Schritt 3, Bild 3 von 3
    • Use a Phillips screwdriver to remove the two 9.2 mm screws that secure the right and left bumpers to the face plate.
    • Gently remove each bumper from the faceplate.
    Frag FixBot
Abschluss
University of Memphis, Team 1-5, Sneed Spring 2024 Mitglied von University of Memphis, Team 1-5, Sneed Spring 2024
UM-SNEED-S24S1G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 39
Insgesamt: 756
