Zum Hauptinhalt wechseln
VTech Baby's Learning Laptop Volume Switch Replacement
Was du brauchst
    1. VTech Baby's Learning Laptop Volume Switch  Replacement, Battery and Rear Panel: Schritt 1, Bild 1 von 1
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      Frag FixBot
      Kommentar hinzufügen
    2. VTech Baby's Learning Laptop Volume Switch  Replacement: Schritt 2, Bild 1 von 1
      • Remove the battery door.
      • Take out the batteries.
      Frag FixBot
    3. VTech Baby's Learning Laptop Volume Switch  Replacement: Schritt 3, Bild 1 von 1
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      Frag FixBot
    4. VTech Baby's Learning Laptop Volume Switch  Replacement: Schritt 4, Bild 1 von 2 VTech Baby's Learning Laptop Volume Switch  Replacement: Schritt 4, Bild 2 von 2
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      Frag FixBot
    1. VTech Baby's Learning Laptop Volume Switch  Replacement, Volume Switch: Schritt 5, Bild 1 von 1
      • Flip your device so the bottom panel is facing up.
      Frag FixBot
    2. VTech Baby's Learning Laptop Volume Switch  Replacement: Schritt 6, Bild 1 von 2 VTech Baby's Learning Laptop Volume Switch  Replacement: Schritt 6, Bild 2 von 2
      • Use a Phillips #2 screwdriver to remove the two 7.7mm screws on the volume switch.
      Frag FixBot
    3. VTech Baby's Learning Laptop Volume Switch  Replacement: Schritt 7, Bild 1 von 2 VTech Baby's Learning Laptop Volume Switch  Replacement: Schritt 7, Bild 2 von 2
      • Remove the volume switch.
      • Be careful not damage the wiring.
      Frag FixBot
Abschluss
USF Tampa, Team 12-2, Blackwell Fall 2015 Mitglied von USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Mitglieder
21 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 46
Insgesamt: 1,233
