Einleitung
Has the sound for your device suddenly stopped working? Unable to adjust the volume? This guide may be the solution to your problem.
Was du brauchst
To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
Remove the rear panel screws using a Phillips #2 screwdriver.
Two 21.6mm (Long)
One 9.8mm (Short)
Five 13.8mm (Medium)
Use a Phillips #2 screwdriver to remove the two 7.7mm screws on the volume switch.
