Einleitung
Tired of sound not working with headphones plugged into your VTech InnoTab 2. Then follow our quick guide to walk you through replacing a headphone jack on your VTech InnoTab 2.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Was du brauchst
Apply slight pressure and slide the button above the battery cabinet to the right to open.
Remove battery cabinet cover by sliding away from the center of device.
Remove all nine plastic caps from the back of the device using the plastic opening tool.
Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
Remove the two 7 mm screws from the left bumper of the device using a JO screwdriver.
Use your fingers to gently remove the headphone jack.
De-solder the points shown to fully remove the headphone jack from the motherboard.
