Zum Hauptinhalt wechseln
VTech InnoTab Max Camera Replacement
Was du brauchst
  1. VTech InnoTab Max Camera Replacement, Cover: Schritt 1, Bild 1 von 3 VTech InnoTab Max Camera Replacement, Cover: Schritt 1, Bild 2 von 3 VTech InnoTab Max Camera Replacement, Cover: Schritt 1, Bild 3 von 3
    • Remove all screw caps from the back panel using a metal spudger.
    Frag FixBot
    Kommentar hinzufügen
  2. VTech InnoTab Max Camera Replacement: Schritt 2, Bild 1 von 3 VTech InnoTab Max Camera Replacement: Schritt 2, Bild 2 von 3 VTech InnoTab Max Camera Replacement: Schritt 2, Bild 3 von 3
    • Next remove all of the now uncovered screws.
    • If there is a cartridge in the device make sure to remove it.
    Frag FixBot
  3. VTech InnoTab Max Camera Replacement: Schritt 3, Bild 1 von 2 VTech InnoTab Max Camera Replacement: Schritt 3, Bild 2 von 2
    • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
    Frag FixBot
  4. VTech InnoTab Max Camera Replacement: Schritt 4, Bild 1 von 2 VTech InnoTab Max Camera Replacement: Schritt 4, Bild 2 von 2
    • Here you can see the back cover has been fully removed and you can now access the front cover.
    • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
    Frag FixBot
  5. VTech InnoTab Max Camera Replacement, Camera: Schritt 5, Bild 1 von 1
    • The camera is not held down by anything, so simply remove it from it's spot to prepare for unplugging it.
    Frag FixBot
  6. VTech InnoTab Max Camera Replacement: Schritt 6, Bild 1 von 2 VTech InnoTab Max Camera Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove the wire connecting the camera to the motherboard, using a tool to grip it if needed.
    • Be careful to only pull from the end of the connector (closest to the motherboard), as the strip is easy to tear.
    Frag FixBot
  7. VTech InnoTab Max Camera Replacement: Schritt 7, Bild 1 von 1
    • The camera is now removed completely removed from the device.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S5-G5, Lacy Spring 2017 Mitglied von USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 49
Insgesamt: 842
