Zum Hauptinhalt wechseln
VTech VM3254 Battery Replacement
Was du brauchst
    1. VTech VM3254 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 VTech VM3254 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
      • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
      Frag FixBot
      Kommentar hinzufügen
    2. VTech VM3254 Battery Replacement: Schritt 2, Bild 1 von 3 VTech VM3254 Battery Replacement: Schritt 2, Bild 2 von 3 VTech VM3254 Battery Replacement: Schritt 2, Bild 3 von 3
      • Use the iFixit Jimmy tool to begin removing the face of the monitor.
      • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
      • Once the screen has been separated, lift it from the case.
      • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
      Frag FixBot
    3. VTech VM3254 Battery Replacement: Schritt 3, Bild 1 von 2 VTech VM3254 Battery Replacement: Schritt 3, Bild 2 von 2
      • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
      • Remove the bracket.
      Frag FixBot
    4. VTech VM3254 Battery Replacement: Schritt 4, Bild 1 von 3 VTech VM3254 Battery Replacement: Schritt 4, Bild 2 von 3 VTech VM3254 Battery Replacement: Schritt 4, Bild 3 von 3
      • Gently remove the battery from its location.
      • Carefully disconnect the bundled cable connector from the circuit board.
      Frag FixBot
Abschluss
Jackson Meacham
109 Reputation
1 Anleitung geschrieben
Utah Tech University, Team 1-2, McMurrin Spring 2023 Mitglied von Utah Tech University, Team 1-2, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G2
4 Mitglieder
6 Anleitungen geschrieben
1 Kommentar zur Anleitung
What is the battery that needs to be replaced called?
Aden Brooks - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 18
Letzte 30 Tage: 80
Insgesamt: 3,028
