Zum Hauptinhalt wechseln
VTech Write and Learn Creative Center Slider Replacement
Was du brauchst
  1. VTech Write and Learn Creative Center Slider Replacement, Back Panel: Schritt 1, Bild 1 von 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: Schritt 1, Bild 2 von 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
    Frag FixBot
    Kommentar hinzufügen
  2. VTech Write and Learn Creative Center Slider Replacement, Slider: Schritt 2, Bild 1 von 1
    • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
    • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 1-2, Miles Spring 2016 Mitglied von UMass Dartmouth, Team 1-2, Miles Spring 2016
UMASSD-MILES-S16S1G2
3 Mitglieder
12 Anleitungen geschrieben
1 Kommentar zur Anleitung
This helps me alot. I haven't took my son's apart yet but my question is when you turn the slider to erase the board it will not erase. Do you think I will need to reattach something or is this fixable if take it apart? My email is caitlinmanderson0@gmail.com if you could kindly email me with any tips.
caitlin28901 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 29
Insgesamt: 753
