Einleitung
The Verizon Ellipsis 10 is a 10.1 inch Android tablet that can be used for many different things such as playing games or for work. This is guide is designed to show how to replace the WiFi module within the tablet. This repair would be done if the tablet is having trouble connecting to WiFi after checking the network settings, restarting device and router, verifying the WiFi password, and making sure it is not in airplane mode. There are no special skills required. Be careful of the sim card and make sure to properly dispose of old WiFi module. Be sure to backup your device before following these instructions so you don't lose any data while completing the replacement. Make sure to power off this device and disconnect from any power source before beginning the process.
Was du brauchst
Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
Once all the clips are undone, the back panel should come off with little effort.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using a pair of tweezers or needle nose pliers, pull up the connecting wire.
Lift the module out.
Eine weitere Person hat diese Anleitung absolviert.
