Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove nine 12mm Phillips screws from the upper back panel. Remove three 12mm Phillips screws inset under the back panel.
    • Remove nine 12mm Phillips screws from the upper back panel.
    • Remove three 12mm Phillips screws inset under the back panel.
    • As soon as the screws are removed, the panel will fall freely.
    • When replacing the twelve 12mm Phillips screws, do not tighten the fasteners until all twelve screws have been loosely fitted back onto the cooler. This will ensure the flimsy metal casing will not warp.
  2. Power Cord Fastener
    • Power Cord Fastener
    • Ground
    • Motherboard
    • Heat Sink Fan
    • Heat Sink
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove two 7mm Hex Nuts. Clearance is minimal and these screws are very tight. You will likely need a socket wrench to avoid stripping. If the white plastic components stick, pry them apart with a metal spudger. Don't pull on the power cord to get plastic pieces to separate.
    • Remove two 7mm Hex Nuts.
    • Clearance is minimal and these screws are very tight. You will likely need a socket wrench to avoid stripping.
    • If the white plastic components stick, pry them apart with a metal spudger. Don't pull on the power cord to get plastic pieces to separate.
  5. Remove one 12mm Phillips screw securing ground. Remove one 12mm Phillips screw securing ground.
    • Remove one 12mm Phillips screw securing ground.
  6. Remove power cable from motherboard. Pinch cable connector to release it from the motherboard, then pull. Pinch cable connector to release it from the motherboard, then pull.
    • Remove power cable from motherboard.
    • Pinch cable connector to release it from the motherboard, then pull.
  7. Your power cord is removed.
    • Your power cord is removed.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jeff Snyder
3.609 Reputation
4 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
100 Mitglieder
7.962 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 539
